Zum Hauptinhalt wechseln
Released in 2015, the ASUS X540s is a 15.6-inch laptop that comes with an onboard graphics processing system capable of outputting HDMI video.
Forgot Windows 10 administrator password and no reset disk
I am locked out of my Asus notebook because I forgot the Windows 10 administrator password. I have no any password reset disk. What should I do? There are a lot of important project presentations in the laptop and I don’t want to lose any of them. Please help!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I forgot my administrator password on my windows 8. I went to Microsoft account and changed password there, but I still get the wrong password message. I've tried this several times, and no joy. Finally, i used passcue for Windows software to create a reset disk, then reset the password successfully.
tutorial:
https://www.passcue.com/windows-10-passw...
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Hi @hannah22,
Don’t worry.
You need a USB flash drive and another accessible computer to help reset your administrator password.
Step 1: Use the media creation tool to create a Windows 10 installation media on another accessible computer.
Step 2: Then start your Asus notebook from the installation media.
Step 3: Replace the Utility Manager (utilman.exe) program on Windows 10 logon screen with the Command Prompt (cmd.exe), so you can open Command Prompt from the logon screen and then reset your administrator password.
For more details, you can refer to this: https://www.isumsoft.com/windows-10/rese...
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Hi @mollie
Thanks for your answer. But I don’t have another computer.
von
If you can borrow one computer from your friend, neighbor, or someone else, things would become easy.
von
Yes, finally borrowed one computer from my workmate, then followed the post step by step and I finally got back my administrator password. I have to type the commands very carefully. The whole process is complicated for me, but I finally did it. Thanks very much.
von
von
Hilfreichste Antwort
Hi @hannah22
You can try this…..
Download this
https://www.hirensbootcd.org/files/HBCD_...
either burn to a cd or to usb.
boot up and use either
  • Lazesoft Password Recovery v4.0.0.1
  • NT Password Edit v0.7
to reset the administrator password
Bewertung 2
2 Kommentare:
I burned this iso file to a USB, start my computer from it and I got into the desktop. But I cannot do any further steps to reset my administrator password. I can open the Control Panel and Command, but I cannot reset my password with either of them. Please help!
von
great info, Thanks for your help
von
Hello, here are several methods for you to reset the login password without old one:
Tip 1: Try to sign in with  the built-in administrator account in Save mode without password, and then reset you current admin password.
1.       On the Windows 10 login screen, hold down Shift key and select Restart in the Shut Down options.
2.       Windows 10 will restart and show you the Advanced Boot Options on startup screen. Select Troubleshoot.
3.       Select Advanced Options in the Troubleshoot screen.
4.       It will show you several advanced options, select Startup Settings.
5.       You are able to restart to change Windows boot options. Click Restart.
6.   After restarting, login with the built-in administrator without password if you have not create a password for it. And then you can open Control Panel to reset other user accounts' password.
Tip 2: Use a Windows 10 Install Media to reset Windows 10 login password.
1. Use your Windows 10 product key to download Windows 10 ISO image from Microsoft site.
2. Free download a Windows Media Creation Tool from Microsoft site.
3. Use the Windows Media Creation Tool to make a Windows 10 installation CD/USB.
4. Once you complete that, boot your computer from the Installation disk and then you can copy and launch Command Prompt to reset password.
Detailed graphic tutorials for Tip1 and Tip 2 can be found here: Three Ways to Reset Windows 10 Password with CMD.
Tip 3: Use a free password reset program to remove your lost Windows 10 password.
1. Free download "Offline NT Password Editor" and "FreeISOBurner", use the Burner to burn the Offline NT program to a CD/DVD.
2. Boot your locked Windows 10 computer from CD/DVD and then follow the instructions on the screen to clear your Windows 10 admin password.
'''++Read more++''' about the detailed steps if you need.
Bewertung 1
You can download Diagnostics and Recovery Toolset 10 (DART) from Microsoft:
https://docs.microsoft.com/en-us/microso...
DART contains a password-reset utility which allows you to reset forgotten Windows 10 password:
https://www.top-password.com/knowledge/f...
Or use the well-known sticky keys method to get rid of the password:
https://www.howtogeek.com/96630/how-to-r...
Bewertung 0
Antwort hinzufügen
Hannah James wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 21
Letzte 30 Tage: 103
Insgesamt: 18,090
