Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Damage to digitizer cable
Replacing the cables after putting in the new battery, there is this warning at step 20:
When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
What does this damage look like? I hooked everything back together for a test and the phone functions BUT: there is a black patch about where the wi-fi, battery charge is shown, and wide grayish vertical streaks on the screen; the screen is also slightly faded. Did I damage that connector? The screen was fine before.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The connector on the 6s isn't too bad its mainly the plus that is temperamental because the connector is physically longer...
The problem u describe sounds more like a faulty screen. Disconnect and check the connectors though make sure it's not bent and the pins dont look like theyve come away from the flex
War diese Antwort hilfreich?
Bewertung 1
Well what happens sometimes is that the connector becomes a bit concaved.
To fix that you put one finger above and one under and attempt to flatten the connector back very carefully.
If you look at the pins carefully on its side you'll see where the bend is very easily if there is one.
Bewertung 0
1 Kommentar:
Both helpful responses. The screen was fine when I began. I have been back through the procedure several times and the cables all seem to seat correctly and the phone will start up but the vertical striations and black patch covering the battery, w-fi status are still there. I don't think I damaged the screen but who knows.
von
Antwort hinzufügen
dbh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 146
