Zum Hauptinhalt wechseln
Repair and additional information for the Samsung RS2556BB refrigerator, a side-by-side model with door access and automatic defrost system, produced by Samsung Electronics Co., Ltd.
Samsung RS265LBBP Cut Wire in Freezer Door
I have an RS265LBBP side by side with water and ice in the freezer door. Ice maker works and fills bucket but ice auger does not dispense ice. After much checking of switch on dispenser, processor board, relays on board. etc., it turns out that one of the two wires going to the ice switch on the door, (the one you press to get ice), was cut. The break is inside the door wall about 3 inches from the top. I am now looking to find how to open the freezer door cavity so I can run a new wire from the ice switch to the top left connector on the freezer door. The front controls are easy to remove by removing one screw. The wiring harness goes through the wall and into the freezer door. Wires exit at freezer door top hinge. The large recessed area where the ice and water are dispensed seem like it can be removed to access the inside of the door but I’m afraid to damage the exterior of the door without some guidance and instruction. The service manual does not show this as a removable part but it clearly is something that is added to the door. Any help?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Hi Guillermo,
I have exactly the same problem with my fridge. Did you find a way to fix the broken wire?
Thanks,
Frank
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Guillermo Munoz, unfortunately there is no way to get inside the door. The insulation is sprayed in after all the wires, water lines etc… are in place. This insulation pushes all the air out so the door won’t sweat. Awhile back, I was curious about what was inside a door, so I took an old door apart. I had to cut the liner off with a filet knife. The insulation is very porous, kind of like chalk. It is in every crack and crevice. The wires were hard to find. Once I found them, I couldn’t pull them free. I had to cut them out. Same with the water line. It made a mess
I’ve never had a wire break inside the top of the door. If you can get enough slack to repair it, you’ll need to buy a new door.
War diese Antwort hilfreich?
Bewertung 3
Diese Antwort bezog sich ursprünglich auf eine andere Frage.
Think about using insulated alligator clips to jump the wire.
If you can’t get to the end of the wire to strip it, use a fireplace lighter to melt it back.
Bewertung 2
Antwort hinzufügen
Guillermo Munoz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 2,412
