Zum Hauptinhalt wechseln
The GSM version of the second generation Samsung Gear round smartwatch running Samsung's Tizen OS. The Gear S2 with 3G GSM was released in October 2015. Model number: SM-R730A.
Replace the small black tap on the back
Gear Sport, Blue'''
MODEL NUMBER: SM-R600SERIAL
The black tap on black is gone. Need a replacement? Can anyone fix or can I order this part? Thx
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
It's not clear what part you are looking for. Can you provide a picture showing more detail? Thanks.
von
Picture was added for clarity.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
This is the only replacement that I could find.
https://rounded.com/samsung-gear-sport-s...
If you do not have one, you will need a tri-wing screw driver. You will also need a splunger or a guitar pick or playing card to pry the back open once you remove the screws.
Here is a simple tear down guide for the Samsung Gear Sport.
Hope this helps. Good luck.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
This is wonderful..thank you, thank you, thank you! I have ordered the back and screw driver and I am sure I will check out the guide once they arrive!
von
Antwort hinzufügen
Lyn Hardway wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 301
