Zum Hauptinhalt wechseln
The 1998 version is based on the original Beetle but, in comparison with the old model of the vehicle, it is way more spacious and equipped with more advanced features.
I have a p1580 code
What does the P1580 code mean ? my litle car has been fine and all of a sudden it doesn’t want to keep running, it is running rough,and I am confused as to why it has this code
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
revaschorus a P1580 pops up with “throttle actuator B1 malfunction”. Could be caused by a dirty throttle body, out of calibration or a low battery. Try this:
Disconnect your battery for 20 minutes and if you have an external battery charger go ahead and charge your battery so you have a strong battery to fire the car on initially.
Now re-connect your battery and turn the key half way where your AC and radio come on (turn your AC off)
Let the car sit for 3-5 minutes. If you put your ear under the hood on the Throttle Body you can hear the TB recalculating, it sounds like an electrical whizzing.
Now crank the car and take it for a spin it should be back to normal except the DTC P01580 still shows. This should reset after 50-75 miles of driving. from here
If that does not work, you will have to clean the Throttle Body as well as the MAF. We can most likely help you with descriptions for that as well.
BTW let us know the exact year and model of your Beetle
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
This is for a 1998 volkswagon beetle 2.0 L
von
The beetles and all the way back have a throttle body assembly(ies) that's('re) sealed and you just have a bad tps(throttle position sensor) usually. That is usually. The cause would be a short and vacuum or could be a bad lead, bad solder, or bad connector plate.
Unfortunately it's the entire throttle body you're seeking as far as a new part.
FOR 90s Jetta golf Passat beetle corrado, and I believe to current with them all. There is no direct SENSOR ONLY replacement for these vehicles. SENSOR ALONE REQUIRES SOLDERING AND DISASSEMBLY TOOLS, YOU REMOVE THE SMALL SENSOR, DO NOT OPEN THE GEARS UNLESS THE OTHERS, AND CLIP THE WHITE WIRE, SPLICE AND REATTACH AS WAS WITH THE NEW SENSOR.
Bewertung 0
Antwort hinzufügen
revaschorus wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 3,795
