Zum Hauptinhalt wechseln
Die Neuauflage vom April 2014 von Apples MacBook Air 11" erhielt aufgefrischte Dual Core i5 und i7 Haswell Prozessoren und eine leicht verbesserte Akkuleistung.
100 Fragen Alle anzeigen
Should I replace my logic board or get a new MacBook?
So for the past year my laptop has been having issues turning back on if it gets shut down completely (restarts are fine). After an event of it shutting down while I was on vacation and then not being able to turn back on, I took it to a repair shop just to see if they could diagnose the problem.
I had some hunch it was the logic board as I just replaced the battery a few months ago since the original one was at the end of its life, and the guy confirmed that my SMC on the logic board is no longer working and that is also why no amount of SMC resets seemed to solve my issue (even though that is googles common answer for my laptop problems).
Now I have 2 (3-ish) choices:
(1) to not replace the logic board and just never shut off my computer and hope it has enough life in it so I can save up for a new Macbook (and get myself a nice upgrade in doing so). With this, I would not put any more money in my macbook but I am estimating I need to save up $2500 because I will want more processing power, more space, and I will have to buy all new dongles. I am thinking I might be able to sell my current Macbook and hope for some money (so also if anyone has estimates on how much I could get for my mostly working laptop)
(2) to replace the logic board ($250+tools) and hope that it gives my laptop more life so I can continue to get my work done for a few more years no problem and then deal with buying a new computer the next time it starts to die.
OR, I guess the third option (3) , but more money is to do a combination where I try to replace the logic board on my computer and then with the (hopefully) extra time save money for a new computer over a longer period of time.
Keep in mind, I feel capable to replace a logic board but not necessarily confident enough in my skills to do a superb, fantastic job
Thanks in advance
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
SMC hardly goes bad unless there was a previous liquid damage or a bad aftermarket charger was used, it’s a solid Japanese IC. Despite the fact the battery was replaced not long ago, general quality level of today’s aftermarket batteries goes from acceptable to awful. I’d first disconnect the battery and try how things work without it.
War diese Antwort hilfreich?
Bewertung 2
Hilfreichste Antwort
Why don’t you have the SMC repaired?
https://rossmanngroup.com/shipping/
Bewertung 2
1 Kommentar:
The prices listed on that site seem pretty much (if not more) than the ~275$ it would cost me to replace the entire logic board. And I feel replacing the logic board is a safer bet since a replacement SMC is gonna have to come from another MacBook anyway so it seems better to keep the board as a whole instead of replacing one part and weakening its integrity
von
Antwort hinzufügen
mifr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 627
