Zum Hauptinhalt wechseln
{A1989 / EMC3214}—Erschienen im Juli 2018. Das 13" MacBook Pro ist mit Quad-Core i5 und i7 Prozessoren und Intel Iris Plus integrierter Grafik ausgestattet.
181 Fragen Alle anzeigen
MLB 820-00850 does NOT match boardview/schematic... any ideas?
i took in a 2018 mbp13 A1989 after a liquid damage and a serious moron opened it up.
several pieces are missing from the MLB, but one cannot be identified as it exists on the board (and the teardown photos) but NOT in the boardview or schematics. has anybody worked on this?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@reverendalc preliminarily it appears to be a 74AUP1T97GM IC Gate. Check the datasheetLow-power configurable gate with voltage-level translator and you may confirm by measureing on the solder pads. Check with Digikey.com or Mouser and see if they have the right package. The part itself is less than $1.00USD
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Awesome thanks I’ll look into that ASAP
von
You'll need to locate a more upto date schematic and board view. The one you have is clearly incomplete. The newer models have been harder to get and I've only found early drafts which are incomplete.
Bewertung 0
1 Kommentar:
Yes it’s clear that this boardview is incomplete. I was hoping somebody may have this board to look at for me...
von
Antwort hinzufügen
Ronnoc Nailli wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 7
Letzten 30 Tage: 19
Insgesamt: 1,590
