Zum Hauptinhalt wechseln
Repair guides and troubleshooting for the Acer Aspire 5, a series of laptops on the Windows OS by Acer.
When attempting to boot, only black screen. Please help
Hi everyone, I just replaced my laptop's HDD with a new SSD but on the screen it said no operating system found. I tried using f2, f8, F10 and F12 to access the bios with no luck. I went onto these forums and one said to short small triangular connectors behind the ram slot and I did so. The device now shows only a black screen, the keyboard lights and fan are on which seems odd, but the screen is totally black. Please help
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Okay let's try a few things:
  • If the laptop has a removable bay and battery try removing the battery first. Then hold power button for 10 seconds, reinsert battery and turn it on again.
  • If there is a removable bay and the coin battery can be accessed remove or unplug the coin battery for 5 minutes then reseat. Try turning it on and see if black screen is still stuck on.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I tried removing the coin battery for 10 minutes and that did nothing, I've also tried to flash a new bios, use function keys to access it, basically everything and it still doesn't want to start. I suspect it's because of a secure boot or legacy boot seeing but I'm not sure.
von
Antwort hinzufügen
Alexander Leigh Stevanoski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 628
