Zum Hauptinhalt wechseln
Veröffentlicht am 23. Oktober 2012 mit Core i5 oder Core i7 CPU, optional mit Fusion Drive
208 Fragen Alle anzeigen
Mac Mini stuck in reboot loop after PRAM reset
I’ve faced this a couple of times, and this is what happens -
I face issues with peripherals - HDDs, keyboards, mice, sound cards, what have you. I reset the SMC and sometimes they work fine. I try to do a PRAM reset and the Mac mini goes into an endless reboot loop. If i forcefully turn it off by holding the power button and then boot while holding the alt/option key, I get a choice of hard disks to boot from, and then I boot into normalcy (so to speak). But I have a nagging problem with a bluetooth keyboard (another post of mine) that I think the PRAM might solve, but I’m now stuck between the faulty keyboard and being able to get work done. HELP!
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Are you using a wired USB keyboard or Bluetooth?
von
@danj I'm using a bluetooth keyboard and mouse
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Why PRAM reset? Why not SMC? I mean SMC is more related to this than the PRAM.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
@fabledkebab - Correct!
In some models the Bluetooth keyboard won't be recognized early enough in the boot up process for the special startup keys which is why you often need to use a wired USB keyboard.
von
You need to use a wired keyboard and you really need to do a SMC reset How to reset the System Management Controller (SMC) on your Mac
Bewertung 1
Antwort hinzufügen
aryansharma.info wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 486
