Zum Hauptinhalt wechseln
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
31 Fragen Alle anzeigen
Where can I purchase propeller blades for the DX-2 drone
where can i purchase propeller blades for the DX-2 drone
Ist dies eine gute Frage?
Bewertung 5
2 Kommentare
how to make the drone fly if it does not work
von
von
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
I'm sure everyone who purchased a dx-2 stunt drone has the same issue. Broken blades on the first flight, and little information about how to get replacements. Fortunately I've found a solution. Even though the blades measure at 57.15mm, which is insanely different than every other drone, you can get away with using 55mm and/or 60mm blades. The 60mm blades are better for lift, but you may need to sand down the tips of each blade, in order to keep them from hitting the guard. Just make sure to measure and mark the blades before you sand, so they end up evenly sanded. But if you don't want to go through that, a 55mm blade will work. You will notice a slight difference in the overall lift and flight, especially if you're a drone veteran. Anyway, you can purchase either of these options online, and relatively cheap too. 8 pairs, on eBay, will cost you between $1.50 and $6.00, and 20 sets of 4 blades for around $10, depending on how long you're willing to wait for shipping, which can be 2-6 weeks. Slow boat from China, or faster truck from California. Just type 'Drone Propeller' and either ‘55mm or 60mm’ into the search bar. Even though the blades may look slightly different, if they fit a 1mm shaft, you should be good. I've found that 75% of the 60mm blades are actually 59mm, which means little to no sanding. If you are willing, and extremely patient, you can get replacement blades from Sharper Image, but the process is frustrating, and it'll cost you considerable more than the eBay option. However, you will end up with identical blades, even though it's really not that important. But some people like samey stuff, so it's up to you. Hopefully this info helps, and welcome to the world of rc droning. In other words, get your pocket books out, and learn how to frankenstein parts together to keep your drones flying.
War diese Antwort hilfreich?
Bewertung 4
Im sure u checked the sharper image official website, just to notice they have no listings for any drone produced under the “dx-” series? Lol. Im not sure brother, and im up that same creek.im thoroughly enjoying my dx-2, mainly because of it's simplicity that I am FORCED to learn to actually fly correctly (including HOVERING) that most people today have most likely not bothered to learn (but what happens if their $600+ drone stops hovering automatically at 400+ meters up…
Hmmmm, they dont know how to fly, UH OH)
But, im gonna checl sites like fasttech and the such, and if that doesnt yield good news, I'll try chexking all the true specs and whatnot and find another Chinese budget drone using the same props and buy them. I'll get back with u on what I find, and hopefully u will do the sane if its sooner than me
Bewertung 2
1 Kommentar:
please do I have this same problem and can't find an answer
von
I read somewhere else, if you call their customer service you can order a kit with a new guard and 8 blades(4 of each) for 4 or 5 dollars. the number is on the manual that came with it, but if you lost that its: 800-374-2744
Bewertung 2
Go on Google and search up a sharper image dx-2 stunt drone propeller replacement kit they're like between 1 and $5 and for the $2.88 pack you get like a set of 20
Bewertung 1
1 Kommentar:
Where do i buy the propellers
von
I don’t think you can
Bewertung 0
anamose: this is a question i have a different BX-2 *DX-2 sharper image
how long is it to charge?…
Bewertung 0
Antwort hinzufügen
ken sullivan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 35
Insgesamt: 6,468
