Zum Hauptinhalt wechseln
Reparaturanleitungen für Kühlgeräte, wie Kühlschränke und Gefrierschränke
1699 Fragen Alle anzeigen
GE Profile Refrigerator not cooling
this is the serial #rf306283 and model#pts22lhparbb for my ge
profile artica have dual control for'top frez bot frig can"t move.cannot get colder frig.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Is your freezer working ok? Or is it that neither the freezer nor the frig is cold enough?
In the mean time, you may or may not know that the temperature settings for this model can be locked in (so know one can change the settings unless they first unlock the controls). Could your controls be in the "locked" mode? I think you have to depress and hold the unlock button for 3 seconds to lock and/or unlock the controls. Might want to try it and see if this allows you to change the temperature settings.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Temperature Control Board
The temperature control board provides voltage to the compressor and fan motors. If the temperature control board is defective, it will stop sending voltage to the cooling system. However, this is not a common occurrence. Control boards are often misdiagnosed—before replacing the control board, first test all of the more commonly defective components. If none of the other components are defective, consider replacing the temperature control board.
Main Control Board
The main control board might be defective. However, this is almost never the cause. Before replacing the main control board, test all of more commonly defective parts. If none of the other components are defective, consider replacing the main control board.
https://www.repairclinic.com/RepairHelp/...
War diese Antwort hilfreich?
Bewertung 2
Hi @ Bertie Haynes,
What is the temp in the fridge section?
Can you hear if the evaporator fan is running in the freezer section?
The fan is behind a panel inside the freezer compartment. If the compressor motor is running, the evap fan will be running (not talking about the condenser fan which is on the outside of the cabinets at the bottom).
When a door is opened (either door) the evap fan will stop running. When the doors are closed it will start again. You don’t want to blow cold air out when a door is opened ;-)
You may have to press an ear against the fridge to hear it stop and start.
If you can't hear it at all, it may be faulty or iced up.
If it is iced up then there may be a problem with the defrost heater or the defrost thermostat.
The fan is used to push cold air flowing over the evap unit, from the freezer into the refrigerator section via the damper to cool down the fridge to the required temp. The freezer will always be colder even if the fan isn’t running as the evap unit which generates the cold is located there.
Here’s a link to the parts for your model. Click on the freezer part diagram to see the location of the evap and evap fan.
Bewertung 2
Antwort hinzufügen
Bertie Haynes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 70
