Zum Hauptinhalt wechseln
Das Samsung Galaxy Note 4 ist ein Smartphone, das im Oktober 2014 heraus kam. Die Modellnummer des Galaxy Note 4 ist bei der amerikanischen Variante eine der folgenden: SM-N910, SM-N910A, SM-N910T, SM-N910V, oder SM-N910R4.
256 Fragen Alle anzeigen
cleaned phone with (isopropyl 70%) , now no one can hear me
the only way the caller or receiver of my call can hear me is if I am on the bluetooth headset or have the loudspeaker on. It started after I cleaned my phone with rubbing alcohol and possibly got some in the tiny holes for the speaker. Its been 3 days and still a problem , what can I do?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
70% alcohol I believe means it is 30% water which may the cause of your problem. It might have to be disassembled and water damage located.
War diese Antwort hilfreich?
Bewertung 0
Aye caramba.
I can’t tell for sure online yet but I think your model has an earpiece mic.
It appears the microphone in the earpiece is damaged(happened to my dads iPhone 6 too,but from water). Did you dump alcohol on it?
When you say you got some in the speaker holes,do you mean the bottom speaker or earpiece speaker(on the phone not your headset).
Either way,if your lucky,just the microphone is damaged and nothing else. The bad part is that it requires me.
Bewertung 0
Antwort hinzufügen
Robert Henry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 28
Insgesamt: 1,138
