Zum Hauptinhalt wechseln
Das Motorola Moto Z3 Play wurde im Juni 2018 veröffentlicht. Es hat ein 6" Display und einen nicht austauschbaren Lithium-Ionen-Akku mit 3000 mAh. Die Rückkamera hat 12 MP, die Frontkamera 8 MP. Modellnummer XT1929-3, XT1929-4 und XT1929-8.
Screen replacement causes digitizer to not work
We are a repair shop and we have tried replacing the screens on this model a few times xt1929-17 and every time the digitizer doesn’t respond on the new lcd has anyone experienced this issue or come up with a fix?
Ist dies eine gute Frage?
Bewertung 10
Einen Kommentar hinzufügen
2 Antworten
I am also experiencing this issue! The digitizer stops responding once you turn the phone off and then back on… it’s a little annoying to say the least. Any guidance on this would be awesome!
Thanks
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I’ve researched and asked local shops as well most have just blamed it on the current quality of the parts on the market being low. Are shop has suspended repairs at the time do to the large warranty rate of the XT models
von
You have to do a hard restart. It’s the only way I’ve found to do it.
Bewertung 0
2 Kommentare:
Could you clarify how you did that? I had the battery cable disconnected, replaced the screen with no problem, and turned the phone on without issue. The problem is that the touch doesn't register, no matter how many times I fiddle with the battery. This was a straightforward, easy fix up until this point.
von
When he says hard reset, he's likely referring to a factory reset.
I haven't replaced the screen on this device yet, but I plan to soon. I'll let you know if I run into this issue and have I might fix it.
von
Antwort hinzufügen
Mike Henry wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 1,155
