Zum Hauptinhalt wechseln
Der iRobot Roomba 880 ist ein autonomer Staubsauger, der 2013 herausgebracht wurde und im Vergleich zu den Vorgängermodellen über mehr Leistung und bessere Reinigungseigenschaften verfügt.
4 year old Roomba 880 squealing while running
UPDATE:
thank you for all your responses we determine that it was the side brush motor. Ordered a new side brush motor and No More Squealing! YAY
Again, thank you all for your help
My 4 year old 880 has starting squealing/screaming while running. I’ve cleaned everything but still scrams. I’m afraid it’s the motor, any suggestions
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Thank you! That’s what we were thinking too.
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
It’s probably the motor, if you’re an expert, you should take it apart - but for most of the time you should ask the previous owner, or company if they can fix it.
Again, what I always say “look it up!”.
Looking it up might not work…
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for seeing this! :)
von Teilen
I had a squealing noise in my Roomba too. which I could trace down to the gearing of the extractor brushes.
The motor was slightly displaced so that the gears didn’t connect properly. I was able to fix this temporarily by adjusting the motor with a piece of plastic. but the gears were worn down already so that I had to replace the extractor housing (including motor and gearing). was not a lot of trouble and is totally doable!
I found the housing in the Roomba shop, but it was a hidden link I only found using google… I am not shure what the situation is where you come from but here in Germany this was also the cheapest offer!
Bewertung 0
1 Kommentar:
https://shop.irobot.de/de/cleaning-head-...
thats the part I bought for ~45€ while Amazon and Ebay were >60
von Teilen
Antwort hinzufügen
SueWormington wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 32
Insgesamt: 3,336
