Zum Hauptinhalt wechseln
Vorgestellt am 16. September 2016. Modelle A1661, A1784 und A1785. Verfügbar mit 32, 128 oder 256 GB internem Speicher in den Farben Rose-Gold, Gold, Silber, Schwarz, Diamantschwarz und Rot.
1366 Fragen Alle anzeigen
iPhone 7 Plus restarts after 3 minutes on 1 % percent battery issues
Please I need your help .. My iPhone 7 Plus screen fell and had a hair like crack but it did not give the phone any problem .. after one month
My Iphone started acting up , it restarts after every 3 minutes when I’m using it and comes on at 1 % when it was charged fully well ,
sometimes the battery percentage goes up and drains down and when it reaches 20 percent most times it stops doing the random restart ,
also when I am charging it it might stop charging and sometimes charge when I replug the charger ..
I have tried my best by doing a reset on my phone and I’ve updated the software to the latest IOS (12.3.1) and also deleted apps and erased all settings , but I’ve not changed the battery .
I don’t know if it’s a battery problem or it’s a software problem or something else
please what is the solution to my predicament??
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You might have a bad part or a faulty component/circuit on the logic board. There’s no way to tell exactly what got compromised with the drop without testing or replacing parts, but that requires parts available. You may try replacing parts starting with battery and lightning assembly that seem the most likely candidates without spending to much money, but be also ready for failure. Alternatively you can walk in a repair shop and let them take care of the troubleshooting.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Nedu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 513
