Where the crank shaft sensor at
Where the crank shaft sensor at on a 2009 Hyundai sonata GPS 4 cylinder.
Ist dies eine gute Frage?
marybostian4 on the 2.4L 4cyl engine the crankshaft position sensor (CKPS) is mounted on top of the bell housing right where the bellhousing meets the engine block.
War diese Antwort hilfreich?
Hard to describe but top left of oem airbox filter you should see the cable
Letzte 24 Stunden: 4
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 83
