How does one fix a power window that does not go up or down
how does one repair a window that does not go up or down in 2005 equinox
Ist dies eine gute Frage?
The motor that drives the window regulator may be faulty. Or the switch may be bad. You’ll need to pull the door interior off and explore the window motor wiring harness for proper voltage and operation from the switch. If this is a rear window, make sure the lockout switch on the drivers door isn’t engaged. Most new cars have that and it always get inadvertently overlooked and engaged.
War diese Antwort hilfreich?
It’s often broken wires between the door and post. Open the door, and pull back the boot surrounding the wires.
Letzten 24 Stunden: 1
Letzten 7 Tage: 5
Letzten 30 Tage: 23
Insgesamt: 1,036
Do you hear a motor spinning or any other noise when you toggle the switch ?
von Hamdi Zeddini
