Zum Hauptinhalt wechseln
The Ford Ranger is a nameplate that has been used on three distinct model lines of cars sold by Ford. Ford repurposed the name "Ranger" in 1982 for the 1983 model year for a compact pickup truck sold in North America and, later, parts of South America.
Sounds like a sick volkswagon stuters with loss of power
98 ford ranger 265834 miles 2.5 4cyl. 5spd manual trans Sounds like a sick volkswagon. Stutters and putters. Losses power especially between shifts. One minute its running great next its not. The catalytic converter was glowing red and because of this I removed it and have straight pipe to the muffler no exhaust leaks and the sick Volkswagen sound sounds like it's coming from the air intake not back at the muffler rural area emissions is not required after removing the catalytic converter a lot of power no longer stalls at lights/ intersection. Ive ran Sea foam thru gas tank and crank case and intake that help restore power aswell. Starts right up hot or cold but you don't know what you're going to get until you go to take off stutter or normal and it seems to have a harder time taking off in reverse I've checked for exhaust leaks vacuum leaks it's not overheating the check engine light was on when I bought this truck 5 years ago remained on all these years up until about 2 weeks ago and that's when these problems started this truck has not given me any problems it's a Workhorse properly maintained. Fuel pump and fuel filter work changed about a year ago and the slave plate was replaced about 2 years ago spark plugs are about a year old oil about three months so what do you think you could be I appreciate your help please.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hey Robert. Have you inspected your spark plugs? Wonder if their condition might tell you anything helpful. I wouldn't be surprised if one or more were gas fouled. Sounds like you might be running on just 2 or 3 cylinders. Lots of possibilities that might be causing your issues, and this is a simple check that might point you in the right direction. Keep us posted.
von
One more thing - On the "sounds like a volkswagon" thing, could a leak at the exhaust manifold account for this?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Have you checked the plug wires? I’ve had similar issues when the wires have gone bad—they just wear out over time. Thing is, they don’t always look bad, so you can’t just eyeball ‘em and call it good.
One way to check: pull into a garage or shed and turn the lights off, or wait until night if you don’t have an indoor place. With the engine idling, spray window cleaner on the wires. If you get pops or the motor misses, the wires need to be replaced. Hey, it’s a cheap replacement. Just do them one at a time so you don’t get the wires crossed (you think it’s running rough now, try swapping a couple plug wires).
The “check engine” light usually indicates a problem with the EGR (exhaust gas recirculator, might be called PCV on older vehicles). If it’s clogged up, it could also be causing rough running/power loss.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I said yes only because i appreciate the answer but its not the plug wires this time . its got me scratching my head its like it will stuter and then like something catches and it surges then i shift it stuters sometimes goes back to normal. Im wondering about could it be the tranny no EGR maybe it does it hot or cold buf more so as it heats up. More so going up hill and struggles almost every time im reveresing.
von
Did you ever figure it out I’m having the same problems I’ve tested literally everything replaced everything I could I am completely lost
von
Antwort hinzufügen
Robert Stathers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 325
