Zumo 660LM voice issues and freezes.
GPS makes random noises, crackling, static, clicking. Sometimes voice just stops working. Often on start-up dim "GARMIN" appears on screen, then unit freezes. Needs many attempts to restart. Sometimes battery removal and replacement after a period of time is necessary to get it working again. Unit is about 3 years old with minimal usage.
Can you offer any suggestions on repairing? Thanks
Ist dies eine gute Frage?
3 Kommentare
It does it when connected to an external power source. I rarely use the GPS on battery only.
Also, a software was recently done and the GPS seemed to work ok for a little while. Then the same problem happened again. I can try another software re-install and see if that does anything.
Thanks for your help.
von Giulio Tomei
Does this on battery power and hooked up to the external power. Did a garmin express update over the weekend which caused the problem
von Marty Gavin
Mine was doing all the above, but would usually function if I removed and replaced battery. Now it does not function. I get the garmin logo but no more. Tried doing update again several batteries with power cord on off , now even the computer doesn’t recognize it when plugged in. Any help? Who can I send the unit to or what could be done?
von GD3
