Zum Hauptinhalt wechseln
Die Xbox One S ist eine Entwicklung von Microsoft. Sie erschien im August 2016 als Neuauflage der Xbox One.
428 Fragen Alle anzeigen
Why won't my Xbox power on?
Well, after a power surge while I was away from home, my Xbox wouldn't power on. I knew it was the power supply because it's meant to do that, to protect the other components. But, even after buying a new one off this website for $20, I have replaced the power supply and it still won't turn on. I followed each step by step and finished. But it just won't power on. I've tried the socket, yes it works, the cable doesn't appear damage (plus I used another one to test), but the console won't make any noise or power up whatsoever. What do I do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Sounds like a blown VRM (Voltage Regulator Modules) circuit on the board. There are components on the board that make up that circuit to power the logic board. That'll require some circuit level troubleshooting and microsoldering to fix.
For this I think getting another Xbox One S would be the cheaper and option (at least for 2nd hand).
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
That's what I didn't want to hear
von
If your Xbox Won’t turn on then it might be battery, adapter, or power supply Problem. Therefore, Check one by one for finding the real cause. Otherwise, You have to replace your Xbox.
Bewertung 0
Antwort hinzufügen
Jorge Ambriz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 2,215
