Problems with a Frigidaire Dishwasher
Hello all.
I have a Frigidaire Model# FDB1500LFB0 and my problem is that…
after loading and selecting my cycle and hitting Start, my washer fills with water to the (I presume) proper amount of water in the bottom. The water is very hot. Then the system stops, and the only thing that will happen after opening it after this (anywhere from 3-15 minutes, I did this several times.) is that when the door is shut back and cancel pressed it will drain as normal. It was left to “run” once and the soap drawer opened, dumping the “pod” directly below it. The dishes had never had water on them and the “pod” was mushy from the ambient humidity, and in a spot directly under the drawer. If left on it will cycle through a fill/drain cycle but the spray-arms never move. I have cut the breaker to it on and off with no change.
Any help will be appreciated, thank you.
Ist dies eine gute Frage?
2 Kommentare
There's two pumps on my dishwasher. If yours is the same the larger pump is bad.
von Reny Hardy
The smaller one is for draining
von Reny Hardy
