Zum Hauptinhalt wechseln
The V2000 is a Compaq Presario notebook computer developed by HP under the Compaq name. The V2000 is the sibling of the HP DV1000, so the two share many features and specifications, though the DV1000 cost about USD $100 more when both computers were sold in the early 2000s.
The laptop only gets on for two minutes?
after switching on the laptop it gets power off after 2 minutes. and have to wait for 30 min to switch it on again.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This could be overheating, does the laptop get excessively hot? If so, open it up, and try and clean as much dirt/dust out of it as you can. Dust builds up inside of computers over time, and can clog vents, fans, and heatsinks inside of the computer, causing it to heat up. Clean out the fans and heatsinks, then try it out. If it is still acting up, the battery may be to blame. You can get a replacement battery on eBay for around $25.
War diese Antwort hilfreich?
Bewertung 6
2 Kommentare:
+ totally agree. Just in case you need the service manual, it is available at http://h10032.www1.hp.com/ctg/Manual/c00... Good Luck
von
+ also consider replacing the thermal paste
von
Antwort hinzufügen
nlovers2000 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 38
Insgesamt: 2,083
