Zum Hauptinhalt wechseln
Veröffentlicht am 21. September 2018. Modelle A1921, A2101, A2102, A2104. Erhältlich als GSM oder CDMA / eSIM oder dual-SIM / 64, 256 oder 512 GB / Silber, Gold oder Space Grau (Ausgesprochen "iPhone 10s.")
20 Fragen Alle anzeigen
My phone turns off after 3 minutes
Im not sure if your able to help, but i have an iphone xs max and i did a charging port replacement pretty easy but the phone stays on for 3 minutes and shuts off battery status seem to be correct everything work it just shut off after 3 minutes what do you think causing the issue and how to fix it
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
I have one doing the same thing it cuts off the powers right back on is this what yours is doing???
von
I changed the screen on mine and after 3 mins mine does the same -.-
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I would try to re-install the original charge port to see if the problem persists. If it does, then you may have accidentally damaged something on the logic board (connectors) or one of the flexes. If the problem is not present with the original flex, then you probably have a defective replacement flex.
War diese Antwort hilfreich?
Bewertung 2
Has anyone figured out the fix for this? After charge port replacement i am having same issue
Bewertung 0
Antwort hinzufügen
Benny Jelleh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,338
