Zum Hauptinhalt wechseln
Das Asus X200CA Laptop hat eine Größe von 11,6 Zoll und wiegt 1,18 kg. Es ist ausgestattet mit entweder einem Intel® Core™ i3 3217U Prozessor, einem Intel® ULV Pentium® 2117U Prozessor oder einem Intel® Celeron® 1007U Prozessor, 2 GB oder 4 GB Arbeitsspeicher, 320 GB bis 1 TB Speicherplatz, Windows 8 Betriebssystem, HD-Webcam und einer geschätzten Akkulaufzeit von 3 Stunden.
Screen is black, computer runs
I had tried a lot of methods I’ve read, for example the ones where I need to remove the battery and hold the power button for several seconds, even minutes, also the F2 + power button and there’s still no response. I was able to connected to my TV. I read somewhere about going to system manager and deactivate the intel graphics. I did that and then i activated them again and I was able to see both screens. I unplugged the Tv did some work on my computer then turn it off. The next day, I turned the computer back on, and was the screen again black, I repeated the method, and it worked. I just feel unnecessary to repeat this process over and over again, does anyone has an idea what do I need to do
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Are you remembering to save your changes if appropriate? Might also want to check your users manual to see if there is a function key toggle for switching between external and internal monitors.
von
Einen Kommentar hinzufügen
1 Antwort
If you can get a display signal to your TV then I’m pretty sure the laptop screen is almost completely dead.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Javier Portillo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 280
