Zum Hauptinhalt wechseln
Geräteseite des Merch Source Projector Entertainment II. Dies ist ein baugleiches Produkt zum Shift 3 Light Blast Entertainment Projector.
What cables do I need to connect my iPhone XR to the projector?
I don’t know what cable I need to connect the projector to my phone
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
What kind of interface(s) does it have?
von Teilen
Being an iPhone options will be limited, check the manual to see whether you can connect it via Bluetooth or wifi
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi Emalee, if you want to connect your iPhone to the projector with a cable then you will need a USB Type C to HDMI cable which will cost you around $10 to $30 in United States. But it has a disadvantage you cant move your iPhone now.
There is another way to connect the iPhone to the projector wirelessly, using a wireless display dongle, so you can move your phone while it’s connected to the projector.
You can watch this video on how to connect a phone to a projector wirelessly, hope this is helpful.
War diese Antwort hilfreich?
Bewertung 2
Even this topic is already 4 years old (and possibly dead for the OT) i would like to enhance the solution for other readers with the same problem.
There are original Apple or 3rd party adapters on the market to connect your iPhone with a projector, depending on the connections the projector provides:
To make it wireless you can use the solution from above mentioned video, or you simply buy an Apple TV device and connect it via HDMI to the projector. More costly, but everything inside the Apple ecosystem.
Bewertung 0
Antwort hinzufügen
Emalee Moe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 22
Insgesamt: 617
