Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Switch might be dirty or sticky, try wiggle a lot to see if intermittent. Otherwise try to pull window it up or slam the door , both while holding the button in up position with car ignition on.
Checked fuses for a start?
von prop man
von uhf mhz
Another think to check is for a broken wire near door hinge where wires go from car into the door.
von uhf mhz
Lynn Reilly what exact year and model is your PU?
von oldturkey03
