Zum Hauptinhalt wechseln
2,26 oder 2,4 GHz/ weißes Unibody-Gehäuse aus Kunststoff
645 Fragen Alle anzeigen
Changed battery and now will not turn on. Charger is orange.
Hi, i recently got a 2010 MacBook unibody. It was stuck in a boot loop, replaced the hdd and turned on, but then it would click off randomly. I managed to get around that by holding the eject key which seemed to keep it on, and i managed to download OS X Yosemite over 3 hours successfully. So all working, apart from the charger would stay green, and if i took it out it would shut off. So dead battery. In the battery tab on the tool bar it said battery needs replacing, not charging. So put another battery in from a MacBook I’m using for parts, the first time i did it i forgot to put the battery cable in, plugged it in and charger was green, opened it up again and realised it was not connected so connected the battery properly and now the charger is orange, but it will not turn on anymore?!?! Any ideas?!?!? Was working fine before apart from the “Click” and shutoff when i wasn’t holding the eject key. Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Leave the mag-safe adapter plugged in until the amber light goes off. Then try starting it up. You currently don’t know if the replacement battery is any good either.
War diese Antwort hilfreich?
Bewertung 2
5 Kommentare:
Thnakyou for your suggestion, the battery light is now green, still not turning on. Was working fine before i removed the flat battery.
von
@iloveangellight Disconnect the battery and mag-safe. Press and hold the power on button for ten seconds. Reconnect the battery then the mag-safe and you should get a spontaneous restart.
von
@mayer just tried it still not doing anything. Any ideas?
von
Is the a battery indicator button on the side of this one, sorry i don't remember. If so press it and tell us what it shows.
von
hi, no its the 2010 model. there is a white light on the front that used to come on but otherwise there isnt any buttons for the battery, the battery is screwed in to the macbook under the baseplate.
von
Antwort hinzufügen
Jennifer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 49
