Zum Hauptinhalt wechseln
Motor shuts off at high speed
When i move the lever to #8 and #10 the motor shuts off. I normally don’t mix at high speed but it was by chance i moved the lever to those positions and discovered the problem. Any assistance would be great. Thank you.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Quoted from the following link:
"If your mixer is only working on certain speeds, you might need to replace your circuit board. Don't worry, follow this guide on how to replace the circuit board."
KitchenAid Classic Mixer K45SS(E)WH Leiterplatte Austausch
Probably a good starting point if you are thinking of doing the repairs yourself. Just make sure you unplug the unit from the AC wall receptacle before undertaking any repairs.
von
Einen Kommentar hinzufügen
1 Antwort
My theory is when you increase the speed above certain level your mixer will start vibrating, this vibration may trigger the safety feature and that causes the motor to stop, to prove that, you need to set the lever at #7 and shake the mixer, if it stops then my theory is correct.
Be careful please !
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Anna C wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 1,408
