Zum Hauptinhalt wechseln
The Grand Prix was updated for 2004 on a revised version of the GM W platform and was unveiled at the 2002 Chicago International Auto Show on February 7, 2002 as the Grand Prix G-Force Concept.
19 Fragen Alle anzeigen
Why is my car dying while I am driving down the road?
As I am driving down the road my car will just die. I lose power steering and power brakes. Once I pull over it will turn back over and start. Sometimes it sounds like the starter might be sticking when I try to turn it over to start. So I'll know it wont run right if it does that and I will turn it back off. Eventually it will start again but may die at any time driving.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
This sounds like a failing or corroded electrical connection. Take it in to a auto parts store that offer free computer read out to help with the diagnostic. AutoZone is one that does it.
War diese Antwort hilfreich?
Bewertung 2
Could be dirty fuel
When was the last time it was serviced ??
It may need a service filters , oil etc
Bewertung 0
2 Kommentare:
I use the middle grade of gas. Sometimes when you try to restart it, it sounds like the starter maybe sticks a little. When it does this I have to turn it back off because I know it will die again while driving.
von
The starter is there to start the car After that it does not come into play at all
It would have nothing to do with the car stopping
It may be the started is stuck
A service by a mechanic I be thinking will solve this issue and ask him/her to inspect the starter
You should get it serviced because block air filter could easly cause the issues you are having and that means not starting or very difficult to start
The engine is not getting enought air throught the air filter
It could also be the injector plugs
von
There is a recall for the ignition turning off while driving it.
Bewertung 0
Bring it to a mechanic. There could be many thinks causing this issue
Bewertung 0
Antwort hinzufügen
juliestokes31035 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 280
