Zum Hauptinhalt wechseln
Veröffentlicht am 26. Oktober 2018. Modelle A1984, A2105, A2106, A2108. Erhältlich als GSM oder CDMA / eSIM, Nano-SIM oder Dual-SIM / 64, 128 oder 256 GB / Schwarz, Weiß, Blau, Gelb, Koralle oder Rot. (Ausgesprochen "iPhone 10 R.")
468 Fragen Alle anzeigen
My invert colors aren’t turning off when it says it’s off
So basically, i did nothing with my phone except watch YouTube videos. Then when I woke up I just see everything inverted colors. So I check settings to try and turn it off but it says its already off. So I was super confused. I even restarted my phone. Please someone help!
Ist dies eine gute Frage?
Bewertung 4
3 Kommentare
Inverted screen or colour combination??
von
Both for me I don't know what to do
von
Go into your display and text size In settings and make sure your classic and there's another one both make sure both inverts are off just make sure they're both off the siri will say that they're Off but they are not so make sure they're off that should fix the problem
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
You can try to reset all settings. This resets WiFi connections,Touch id,password,etc. no important data is lost. No pictures or anything else is deleted. Only settings. This could fix a software glitch.
You can try to update the iOS as well. This can be a bug in your current iOS version.
Worse case you can factory reset the iPhone and set it up as new. This usually fixes any software issues.
War diese Antwort hilfreich?
Bewertung 2
Go to siri and say turn off inverted colors
(Idk if this will work I’m just trying to help)
Bewertung 0
2 Kommentare:
Thank you so much, I tried everything else but nothing worked then I tried Siri and it finally worked
von
ive been having the same issue and it wont work it already “has inverted colors off”
von
Antwort hinzufügen
kieu nguyen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 61
Insgesamt: 4,225
