Zum Hauptinhalt wechseln
The Hp Notebook 15-ba018ds is a touchscreen capable laptop equipped with Windows 10 operating system. It is 16 x 10 x 3 inches when closed and weighs 4.83lbs.
Is the storage upgradable?
I want to place an SSD inside my laptop to make it run quicker. Is it possible to add an SSD or M.2 to this board?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
The specs here state " Hard drive 2 TB 5400 rpm SATA" so ssd should be possible. No mention of M.2" though.
https://support.hp.com/us-en/document/c0...
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Yes, you can install a 2.5” SSD drive:
https://www.crucial.com/usa/en/compatibl...
War diese Antwort hilfreich?
Bewertung 2
Hi,
Looking at the service manual for the laptop, taken from this webpage if you wish to insert a M.2 SSD rather than a sata SSD you’ll need to change the drive connector board in the laptop
Scroll to p.50-52 to view the HDD removal/connection procedure and to p.55-56 to view the M.2 SSD removal/connection procedure.
On p.56 you’ll find the part number for the M.2 SSD drive connector board.
If you wish to install a M.2 drive, search online for the M.2 SSD drive connector board using the part number only (850946-001) in the search term of your browser, you’ll get results for suppliers of the part
Bewertung 1
Antwort hinzufügen
Luis Loera wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 193
