Zum Hauptinhalt wechseln
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
Dead critter where water flows into washer
Evidently a critter, most likely a lizard, has managed to get into my washer and crawl into the little slot where water comes into the machine. I have no idea as how to remove it! It isnt clogged inlet filters or a bad valve, this is inside the washer. Any suggestions?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Can't seem to Google an exploded view of your unit so this is just a thought. Maybe try popping the washer's lid and seeing if the mounts for the water discharge slot are visible?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Thanks, had to take the back off, take the inlet valve assembly but we got it. It was actually a mouse, how the heck it got to where he did is a true mystery! I had tried googling info as well and got help for everything but this issue.... guessing it doesnt happen very often!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
nttygrl39 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 64
