Zum Hauptinhalt wechseln
Veröffentlicht am 26. Oktober 2018. Modelle A1984, A2105, A2106, A2108. Erhältlich als GSM oder CDMA / eSIM, Nano-SIM oder Dual-SIM / 64, 128 oder 256 GB / Schwarz, Weiß, Blau, Gelb, Koralle oder Rot. (Ausgesprochen "iPhone 10 R.")
468 Fragen Alle anzeigen
iPhone xr lcd screen?
I bought a xr from a repo company but there is no lcd with it just the base of the phone works perfect seen in itunes.
But id like to know what problems I could run into when I put a screen back on it I plan buying a full transplant from a iclocked on of ebay will face id and front camera still work as bear in mind ive no screen or parts ?
thanks
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Anything or nothing. Really no way to tell without trying.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I'm pretty sure the face iD will not work , unless it's the original screen.
War diese Antwort hilfreich?
Bewertung 1
If you buy a screen that was formerly iCloud locked, it won’t make no difference to the screen. Only difference is the device itself it WAS iCloud locked. So yes, you can take a LCD screen off an iCloud-locked device, since it only effects the logic board INSIDE the phone, all the other parts won’t be effected. So everything else can be tested like it should, though i’m not sure if Face ID will work as it is from a difference phone, but it is worth trying if that’s what your curious about.
Bewertung 0
Antwort hinzufügen
sam M wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 167
