Zum Hauptinhalt wechseln
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
Why is my chromebook not turning on?
After using, I closed cover—next time I opened it, it would not turn on, with or without power cord plugged in, and no (charging indicator) lights come on when it is plugged in. Battery had plenty of charge when I closed it down.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It appears from the following that the unit can be booted minus the battery being hooked up. To eliminate the battery as a potential source for the non-booting problem, I suggest you disconnect the battery and try booting the unit again.
Why is the computer not charging or booting? Battery removal works..
For further information and tutorials (including removing the battery) see:
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
K Einspahr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 310
