JBL Speakers Not Working
I think one of the speakers in the 2.1 JBL speaker system is busted. Is there a way I can test this and also how do I replace the broken speaker?
Ist dies eine gute Frage?
Right click on the speaker icon in the taskbar notification area. Select sound. Select playback tab, double click on speakers, select level tab in speaker properties click on balance. Now adjust the sliders so that one side cuts out while sound is still coming from the other side. Repeat for the other speaker.
You also try using VLC -> Audio -> Visualizations to see if VLC is processing the audio signal from both audio channels as it may not be your speaker itself that is of fault but a component in the audio processing circuitry instead.
As for replacing a speaker, googling or youtubing for “teardowns” or “repairs” plus your model number usually produces positive results.
War diese Antwort hilfreich?
The parts can easily be sourced, and replacing the parts is really easy, this model in my experience has serious problems with the rubber inside the speakers, mainly the subwoofer, rotting.
For the diagnosis, the previous answer is great on that matter.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 559
1 Kommentar
BTW, always a good idea to add what operating system and version number you are using to your question(s). :-)
von prop man
