Zum Hauptinhalt wechseln
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
31 Fragen Alle anzeigen
Altima coupe headlights flicker and cut out
2009 altima coupe headlights flicker and cut out. Been having issues with driver side, flickers once in a while then will cut out. Can turn headlights off and back on and everything comes back on like normal. Passenger side is now flickering as well.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
My first thought would be a bad or partially broken bulb. Hit any hard bumps lately?
Any other lights flicker at all when you switch your headlights on, like your brake lights or dash lights? Does it improve it all or change behavior when you play with the headlight switch?
Because it is affecting both sides of your headlights, assuming the bulbs are good, I would then look at the fuse/relay for the headlamps followed by the headlight switch being the possible causes. A corroded or failing fuse/relay could display similar symptoms.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
James McConnell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 974
