Zum Hauptinhalt wechseln
1,4GHz oder 1,6GHz Prozessor, 64 GB oder 128 GB SSD.
162 Fragen Alle anzeigen
Will this Mac Air power up safely with battery removed>
MacAir 11'‘ Late 2010 with a bulging battery (keyboard puffed up). Charger cord shows a green light. It powers on with the charger, but I get only a lighted LCD screen with a slash-circle at its middle that periodically alternates with the Apple logo. Doesn’t go to boot at all. Is it safe to remove the battery and operate the laptop without that battery? I’m hoping the logicboard and SSD are still OK. I’d buy a replacement battery only if I see everything else works fine.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Oh Boy! You got a few issues.
Yes your system can boot up without the battery. You’ll need to take the battery out and disconnect the charger. Press the power button for a minute to drain the logic. Once thats done plug the MagSafe back in you should be able to boot un now.
But! You appear to have a second problem which is then getting it the way! Your SSD does not have a workable OS on it as you are seeing the Prohibitory symbol
About the screens your Mac displays as it starts up
Lets try this restart the system this time and press the Option (⌥) to get to the Startup Manager. Do you see a valid OS present? If you do select it and your system should boot up. If not you’ll need to boot up from either an external bootable drive or leverage Internet Recovery (this time pressing the Command (⌘) and R keys) to then create a bootable external drive so you can then try to fix your internal drive.
Mac startup key combinations
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Yes I have done the Option routine, and it shows the Mac OS as the only available bootable OS present. However, choosing it only leads me to the Prohibitory symbol and then no more boot process. I’m hoping the bulged battery is merely pressing loose some logicboard connections and removing it will return the laptop to normal operation.
von
You may need to reformat the drive and install a fresh OS. If you have data you want to recover and you have a second system leverage Target Disk Mode Here's some of the ways you can use it Understanding the Applications for Target Disk Mode
von
Update:
I removed the bloated battery but still can’t boot from the SSD. It’s probably corrupted. So I booted from the USB stick I had for late 2010 Mac Airs and formatted the main drive (Mac OS Journalled). I tried to restore the OS (using Disk Utilities) from the hidden partition containing the factory disk image in it but still no joy. I ended up installing the original Snow Leopard OS from the USB stick into the main partition and now everything works.
Bewertung 0
Antwort hinzufügen
Bernie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 76
