Zum Hauptinhalt wechseln
Hyundai's entry-level vehicle. It's available only as a sedan; the hatchback was discontinued after the 2017 model year.
Why does my car stop turning over?
2002 Hyundai Accent
1.5 L, 4 cyl. Manual Transmission
The issue started with taking an extra few seconds to turn over completely and start and ended with not being able to start at all.
It would try and try as long as you turn the key over but no full start up.
I changed all 4 spark plugs, it reluctantly started and I drove it about 10 miles to my house.
Then again this morning as I try to leave, same problem. Wont start.
Starter had been replaced 1.5-2 years ago. Alternator 3 years prior. Battery is only 2 years old.
Any answers appreciated!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@vonnie "taking an extra few seconds to turn over completely and start and ended with not being able to start at all.
It would try and try as long as you turn the key over but no full start up."
Does the engine turn over when you try to start? Does it sound like it did before all of this when it turns over? If the starting speed is to slow then you may have a starter issue or a battery issue. The spark plugs will not have anything to do with that. If it does turn over fast enough then you may have an issue with the spark but could be any sensor, coil etc. as well. We definitely need more information to help you out better.
von
Einen Kommentar hinzufügen
1 Antwort
What does your new spark plug look like now, is it all black, do you know how to test for spark with the spark plug out of the cylinder, you need a helper to turn the key. I will assume you have coil on your spark plug, take a plug out, put it into the coil, ground the threaded portion of your spark plug to metal on the engine, start with the key and see if you have spark easily or sometimes or not at all, we need more information please, is your check engine light on when you are driving before??
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jennifer Vonnie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 252
