Zum Hauptinhalt wechseln
Dokumentation und Anleitungen für die Reparatur des am 22. September 2017 veröffentlichten iPhone 8. Modellnummern A1863, A1905.
873 Fragen Alle anzeigen
Not charging but recognizes in 3utools
I have an iPhone 8 come in for repair from a customer…..
Anyways, the iPhone 8 does not charge. I even put a new battery in and it’ll boot but will not charge. It works perfectly and read with 3utools and shows proper battery percentage so I don’t think Tristar is involved. I also checked on the board for q3200 and q3201 and they are there and not missing. The resistors are also on the board. What would be the culprit of this on board?
I also tried a new charging port and still nothing. My amp meter shows 0.02amps when a new battery is connected and on…. However , battery icon doesn’t turn green for chsrging.. what’s most likely fault? It feels o me it’s missing some sort of 5volt rail or something or usb connection to charge…
Thank you
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
This problem is complex to solve that you need to check all the pads of charging connector.Charger gives the voltage but circuit don`t accept the voltage.
Possible solution.
1- Check the charging pin for band and loose connection.
2-Check the resistor open on the connector line.
3 -Check the I2C line.
4 - Trister reverse gate track.
5 - M5500 might be faulty remember M5500 has AP EEPROM inveld there.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I've checked forOL ON BATTERY CONNECTOR AND EVERYTHING IS FINE... I am not very crazy knowledgeable on board schematic but I do have some knowledge using zxwtools...
For ol, q3200 and q3201 and the resistors seem fine...
von
Antwort hinzufügen
Daniel Ringuette wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 665
