Zum Hauptinhalt wechseln
Das Pixel 3a XL ist die größere Version von Googles Smartphones der dritten Generation und ist mit der gleichen Kamera wie die Flaggschiffe von Google ausgestattet. Erhältlich in Weiß (Clearly White), Schwarz (Just Black) und Purpurartig (Purple-ish), erschienen im Mai 2019.
When I turn my screen off and back on screen becomes unresponsive.
I recently replaced my screen and when I first turn it on everything works fine, but when I turn off the screen and then turn it back on, everywhere I touch just brings up the pull down menu.
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
TO the original poster, I am facing the exact same issue after replacing my broken screen, were you able to find a fix for your issue?
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
To anyone facing this issue, the problem seems to lie in the replacement screens themselves. A workaround is to go into Settings > System > Gestures and turn OFF “Double Tap To Check Phone"
After turning this gesture off, the phone works normally.
War diese Antwort hilfreich?
Bewertung 1
This sounds like a faulty display assembly or possibly even just a poorly seated cable. If you can, try to pop off the display connector and give both sides a gentle clean with some high % isopropyl alcohol. If the screen is still unresponsive, it’s likely to be a bad display assembly.
And unfortunately if the same behavior is present on multiple displays, it’s possible the board was damaged somehow during repair, in which case, you may want to look for a new device or send it to a board repair service.
Bewertung 0
Bewertung 0
Antwort hinzufügen
Sany Dan Muk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 631
