Zum Hauptinhalt wechseln
Ein 2013 hergestelltes Budget-Notebook von Acer aus der Aspire-Produktlinie.
Laptop not switching on
Hi
My laptop is not switching on, I have checked the power adapter and the battery and there are both working. I get the orange light when it's charging and I get the blue light when it's charged how ever when I switch it on nothing happens. What is the cause and how do I fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Re insert ram and HDD in your laptop this may fix your problem
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi Shnisani,
for first, can you answer, how did it happen? Or, is there any helpful information which can help with the solution?
It’s look like BIOS stuck or just RAM bug, try:
  • Reset your bios using CMOS reset (disconnect power, battery and the small battery on the MB, if it’s model without battery on the MB, try to press the power button for about 30-60s and then it may be work - or pressing)
  • Unplug your RAMs and clean slot, then, insert only one (if you have more) and try to turn on, if nothing, select another slot
  • Disconnect your HDD and try to boot without it
  • Check cables from MB to display
It may be the only bug, but we need to know if the laptop is turning on without cooler start if the HDD is working while the laptop is about to start.
If nothing worked, write more description of your issue to comments.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you
Lucas
i switched the Ram slot and removed the battery and the small battery on the MB then i press the power button for 30sec .
put everything back and when i put on power without the main battery, the LED light came on and i presspressed the power button and everything came on.
Thank you
von
Hi Shnisani, so well done! :) I'm happy that you have solved your issue.
von
Hi Lucas
My Acer Aspire ES 14 doesn't turn on with the battery on it and even without the battery, it still doesn't work. Please help me. Thank u!
von
Antwort hinzufügen
Shnisani Ranpfumedzi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 2,392
