Zum Hauptinhalt wechseln
The first-generation Ford Focus was manufactured in Europe from 1998-2004 and in North American from 1999 to 2007.
How to put shaft back in ignition housing so I can put ignition barrel
How to aline the shaft on ignition housing to aline with the ignition barrel
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I think we will need some pictures or a link to a video on your specific vehicle to get a better idea of exactly where you are in the process please. If you have the key cylinder with the key out, you need to insert the key and turn it one click clockwise to be able to insert the key cylinder with key into the assembly and push it inward with a little force to get in past the holding lock, then turn off the key to remove it like normal.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Andrew Jones wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 138
