Zum Hauptinhalt wechseln
Die Apple Watch Series 1 ist eine Überarbeitung der ursprünglichen Apple Watch, sie wurde am 7. September 2016 angekündigt. Die meisten Teile sind die gleichen wie bei der Series 2
120 Fragen Alle anzeigen
Horizontal lines going through the screen
I recently toon my screen off. When reattaching it, the display have horizontal lines going through the whole screen. What would needs to be replace in this case?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Ouch!
You managed to damage the display. The cost of a new display is about $85 ~ 120 depending on the size and glass.
Apple just lowered the price of the Series 3 depending on how worn yours is you might consider it.
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
Well the watch is a series 1 42mm. So the screen shouldn’t be too expensive.
von
have you managed to fix it? I have been the same problem after changing the force touch sensor?
von
@Abhishek Kaushik - I'm sure replacing the display solved it!
von
Do you know where can I find the display?
von
@Abhishek Kaushik - They are becoming hard to find, sorry I don't have a source to offer you.
von
If you struggle to find a new screen look on eBay for a spares or repair watch the same as yours with a good screen and use that. Cheaper than a new one too. I used to repair fitbits this way.
Bewertung 0
This is what it looks like, so I’m not sure if I messed up the display or the connectors.
Update (10/05/2022)
When powering on it looks like this
Bewertung 0
Antwort hinzufügen
Tyler Young wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 10
Letzten 30 Tage: 39
Insgesamt: 2,953
