Zum Hauptinhalt wechseln
2.0GHz, 2.3GHz, oder 2.6GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
580 Fragen Alle anzeigen
MacBook Pro 15 Battery Stops Charging When Launching Energy Impact App
When by MacBook pro battery is charged below 80% and is charging, every time I launch an app that creates a short leap at energy impact graph in Activity Monitor, the battery stops charging. Most of the time launching the Safari does that. I have to plug out the charger from the network and plug it in again to continue the charging process. When battery is charged above 80%, the problem disappears.
SMC reset or recalibrating didn’t help. Besides this the battery works just fine, I am able to work for 3-4 hours on one charge.
Full charge capacity is 6388 mAh
Cycle Count: 823
Amperage: 2950
Voltage: 11655
Is it just dying or should there be a fix?
Thank you!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Your battery needs to be replaced!
A weak battery will respond like this. Your batteries cycled count is close to its end of life MacBook Pro 15" Retina Display Late 2013 Battery Replacement
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Michael wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 36
