Zum Hauptinhalt wechseln
Angekündigt im August 2017. Das Galaxy Note8 ist der Nachfolger des durch Rückruf bekannten Galaxy Note7. Erhältlich war das Note8 im September 2017.
148 Fragen Alle anzeigen
I shattered my screen, and now a portion of it wont respond to touch.
I shattered the screen on my note 8 further, a day after ordering replacement glass for a relatively small fracture it already had. I have a little bit of experience fixing stuff like that and was planning to try to fix it on my own, however now the middle third of the screen is unresponsive to touch. Would replacing the glass fix this, or should i order a new AMOLED?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
if you can see everything on the screen perfectly fine and it’s just the glass that is shattered and unresponsive to touches replacing the glass would probably fix it but it might be much harder than replacing the whole assembly
War diese Antwort hilfreich?
Bewertung 1
Hi @c0nman46
As long as you ordered a quality replacement screen, all of your issues should be resolved with a screen replacement. Damaged Samsung AMOLED screens tend to degrade worse and worse over time until they do not function at all.
I’m hoping that you ordered the screen pre-installed on a frame, otherwise this will be a VERY difficult repair.
Best of luck fixing this up!
Bewertung 1
Antwort hinzufügen
Con Coster wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 47
