Zum Hauptinhalt wechseln
Repair and disassembly guides for the Compaq Presario CQ60.
28 Fragen Alle anzeigen
Why my leptop is shutdown automatically?
My laptop work fine for first 10 sec and then its shutdown automatically and after first shutdown it just show the logo of windows and shutdown again it’s working fine in safe mode but when i start downloding anything in safe mode it’s shutdown again please help me in my problem please
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare:
What operating system are you running?
von
I am using windows 7,
I try to format it but is not working it's shutdown quickly.
von
@tejas limbachiya Is there a certain amount of time it shuts down after? Does it work for 5 minutes and cut off? 30 seconds? I need more information.
von
It work for like to r minutes for once in a day and after first shutdown it's shutdown immediately shutting down when I trying to start again
von
Einen Kommentar hinzufügen
1 Antwort
You have an overheating problem, there is a safety switch that shuts down your computer immediately when the CPU overheats, the first time when you turn on your laptop, your CPU is at ambient temperature let’s say 25°C then it jumps to around 100°C and trigger the emergency switch, in the second try your CPU is no more at 25°C but somewhere around 90°C which means the CPU will reach the threshold temperature (100°C) much faster.
In order to cool down properly the CPU, you have to check first your fan if it’s spinning or not and clean up the radiator.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
tejas limbachiya wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 700
