Zum Hauptinhalt wechseln
Ein Samsung Smartphone, erschienen im Januar 2016. Modell SM-J320
Why wont my screen work?(Black Screen of Death)
Hi, so on my J3 2016, I went to turn it on one day but it didn’t. I just assumed it was dead, so I plugged it in. When I plugged it in the phone vibrated, so I thought it was charging and left it there. Fast forward 3 hours later, I come and check on it, and it doesn’t power on. How can I fix this?
Thanks in advance!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
What causes you to believe this is the black screen of death? What steps have you taken to narrow this down? Your description doesn’t rule out a simple power, battery, or charging issue.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I tried multiple chargers, took the battery out and plugged it in to see if it would turn on. Also, when I plug it in, it vibrates but nothing shows up.
von Teilen
Gotcha. You are right that it's taking a charge. I don't want to jump the gun, but out of curiosity, have you tried a hard reset using the hardware buttons?
von Teilen
Hilfreichste Antwort
Hi @random_user_101
Generally if the phone works properly with nothing on the screen, it is a screen related issue. You can check the screen connection easily from the connector on the backside of the phone.
If you are still having screen problems, you may need a replacement screen assembly.
Bewertung 1
Antwort hinzufügen
Random _User_101 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 1,207
