Zum Hauptinhalt wechseln
2.0GHz, 2.3GHz, oder 2.6GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
580 Fragen Alle anzeigen
Magsafe orange light blink 2-3 times in 10 seconds - not power on but
Hey ,
I’m not sure how this is start (maybe some short in the before adapter - now it fixed)
The Mac is not turn on, I replaced to new battery but same behavior - you can watch this video: https://www.youtube.com/watch?v=YAniGEWm...
While I opened the back cover after replacing the battery I plugged it to the power and tried to turn on, the screen stays black but it’s looks like the fans are spinning and stopping - like coordinates with the orange light blinks.
Please see if you can help any how.
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Your system looks quite banged up! Can you give us a bit of history and why you thought the battery needed replacing.
von
Nothing special, One day out of the blue it start.
I looked for this behavior on the internet and found some article on unplug the battery and plug it back after 10 seconds.
I did that but without a luck, I also tried to plug the power without battery but still without a luck.
I thought maybe a short in the power adapter dried the battery so I decide to order a new one, I got it yesterday and replace it but still same behavior :-(
Do you have any thoughts ? do you need more picture video of something else in a matter to understand better the problem?
Thanks
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Okay, So after many investigation and troubleshooting the problem solved by changing to another power adapter.
Thanks all
War diese Antwort hilfreich?
Bewertung 1
Easy fix is always to clean out the MagSafe charging port to get rid of anything that might prevent a good connection. Use a generous amount of mild cleaner and a small brush to scrub out anything that shouldn’t be there.
Bewertung 0
Antwort hinzufügen
purian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 430
