Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare:
Why do you think you need to remove it?
Safe Boot can't be removed as its part of the firmware and OS. How about explaining your issue maybe there is an alternative.
Are you saying the machine boots in safe mode across reboots even when you don't hold shift? Perhaps a boot parameter is set, did you try clearing the NVRAM?
von Dan
von Ted
