Zum Hauptinhalt wechseln
Veröffentlicht am 22. September 2017. Modell A1864, A1897. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Gold, Silber und Space Grau.
678 Fragen Alle anzeigen
charging and home buttons not working after screen replacement
hi, so i’ve recently replaced the screen on my iPhone 8 Plus, and now i’m facing the following problems with it:
  • it’s only charging wirelessly, tho the Lightning port is giving audio signals to the headphones.
  • the home button is not working, but Touch ID does.
what do you suppose is the problem?
Update (10/08/2019)
also, it turns off by it seld when shaken or moved too much
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Charger port might need replacement
The home button could be effected or if you have another screen to try it on to see if old screen isnt completely broken test it on the old
War diese Antwort hilfreich?
Bewertung 0
The loss of home button functionality while retaining the use of Touch ID is likely caused by damage to the IC that is on the home button. To resolve this you could either bring it to Apple for a screen replacement (where they’ll replace the home button with the whole display) for $219.00CAD or you can order a replacement home button from JC or HX and you’ll regain the home button, but lose Touch ID functionality.
As far as the charge port issue, it could be some damage to the flex cables that is preventing charging but allowing audio, you’d have to connect a working chargeport to the phone and see if there’s any change.
Hope this helps!
Bewertung 0
Antwort hinzufügen
Bibars Bara wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 567
